NordicNerd
Ok so I have a small system - all I need to do is connect the pieces now that it's all mounted. The Giandel does NOT have a ground-neutral bond so this will be done in the panel.
QUESTION:
Should I put one 30 amp breaker in the panel acting as my main disconnect with a second one feeding my circuit, or just use one to feed my two outlets (one inside and going outside)? Most everything else I have figured out.
Thanks All!
QUESTION:
Thanks All!
