AlaskanNoob
- Feb 20, 2021
- 959
So we've got our 8 Pylontech batteries in our solar shed which is located above a root cellar. Turns out the Alaska winters laugh at my attempt to insulate the batteries. So I'm going to move them down into the root cellar with room to double them, into a super insulated wood shelf.
The shelf will sit on a concrete floor in the root cellar and will hold the batteries a couple feet off the ground close to the ceiling of the root cellar, which is the floor of the shed, to shorten cable lengths going to the bus bar on the wall in the shed above.
Four shelves that will hold four batteries each, so each shelf will need to hold 352 pounds or so. The total will be 1408 pounds or so.
Will spray closed cell foam around the outside to super insulate it and have doors with hinges for access.
Thinking the base will be a rectangle with a support in the middle as well with blocking in the middle of each shelf to help support the shelves.
Thinking the base will have diagonal supports on three of the four sides, so the space under it can be used for storage.
Recommendations on the design? Thickness of the wood shelves or the base?
