l00semarble
- Jan 1, 2022
- 151
I understand the reasons. A stock alternator directly connected to Lithium is a problem as the low internal resistance will cause high continuous currents and kill the alternator by heat. But many (most?) serious cruisers who rely on an alternator for significant battery charging will have a high output/heavy duty alternator and an external regulator (such as Balmar setup.)
The beloved Victron DC-DC charger is great and often recommended as the solution for DC-DC charging of a LiFeP04 bank from the alternator on starter lead acid bank. This makes sense and is safe/conservative but at 12v you are limited to 30 amps which is a joke if you have a 120a, or 150a or perhaps even larger alternator. Balmar XT series goes to 250a in a small case alternator. It would be such a waste to have a huge honkin' alternator and only use 30a of it.
yes you can parallel the DC-DC charger but if you want to make good use of a 150a alternator you would need 5 of them in parallel which is totally impractical.
Even with a bone stock alternator rated at 60-80a putting a 30a DC-DC charger is going to cripple recharge rates which could really impact a cruiser's lifestyle if they have no generator and are using the alternator as a primary charging source.
Obviously any other solution has to keep many different factors in mind. A alternator temp sensor on regulator is critical and not allowing any chance of a BMS open circuiting a alternator is also critical. But there are ways to do this other than an undersized DC-DC charger.
Why is this always the "go to" recommendation? Just because it is easy to be safe despite performance?
