Martians
I expect the combination of cold and lack of moisture will create challenges to create a safe path for stray currents to "ground" on Mars. This was actually a real problem when I worked in permafrost areas of the Arctic, the "ground" didn't conduct electricity reliably.
Yeah, significant lack of groundwater on mars will make resistance FAR above 11ohms...
You should see if you can get a grant to study this problem.
it has been studied,
the solution involved directional drilling into areas below large lakes, where the perafrost was significanly thinner/shallower.
Was a big item to get done in a remote locale.
It must be placed horizontal in a trench with continuous drip irrigation.
We are all laughing, but ive read studies where solar particles cause thousands of volts in certain areas on the moon. Nigh zero moisture will make grounding to shed those electrons... metoric...
