I have two LV6548v2 inverters, 25K solar, 50Kwh battery with utility power input only to make up the power difference. None of the inverter output connects to the utility. I only use utility for supplemental.
Issue: I charge my Tesla at 11:45 am. My Solar batteries are usually 100%, solar is not enough to 100% charge Tesla. Usually, 80% is solar, and 20% is offset by utility. Got tired of doing battery dance so I charge solar-utility-battery
The utility company sees a 1-watt back feed ripple when I start charging my car. They know I have solar and are wanting me to fix the issue or turn off the solar
The Tesla charger is downstream of the inverter.
This is where I am at.
Going to install a Grid Only EV Charger.
Going to completely disconnect the utility input.
Concern
Can a battery charger, EV charger, etc cause this ripple? I am afraid no matter what I do the minute I ripple the system (instantaneous high demand) the utility will go we warned you not to do this again we are pulling the meter.
Is the LV6548 the issue? It's only supposed to go one way input
Need help?
Concern
Need help?
