Other than a traditional rail system, are there any good mounting systems that work well with a roof that has had a silicon coating applied? Whatever I go with I will likely have the roofing contractor come back and add a layer over any new penetrations. The underlying roof is modified bitumen and it is a cathedral ceiling below with no attic. Rafters are TJI's on 16" centers and decking is likely just 1/2" plywood.
The panels will be installed parallel to the roof plane and can easily be landscape or portrait, although portrait is a little easier to access. Only for 6-8 panels. No snow risk.
Thanks!
Thanks!
