sabo
The MPP manual says to use 4 AWG for the AC Input and Output. I assume that is because they assume I will be building a 100 amp system. I have 1 inverter now. I have 6 AWG running from the main panel to my sub panel. I already ran a 6 AWG run off that sub panel for a second sub sub panel. I am now planning on using that 6 AWG run for my inverter and not for the second sub panel as originally planned. If I add an inverter at some point in the future I would run 4 AWG from the main to the sub panel and then again from the sub to the inverters. Are there any problems with this plan?
TIA
TIA
