Mpp LVX6048WP or LVX12kwWP Battery current limiter / gate?
Albert Florida
Bradenton, FL
Any info on the battery current limiter, I would imagine you could set it at 10 Amps or 20 and it will trickle the power on the loads without killing the batteries in the first hour. anyone tried it? does it work on the LVX 12kw WP ?
Thanks, Albert
LVX 12kw WP pictures, got it, now how to set it up? it likes to be a UPS at the moment , more than other inverters. ??
Now comes the trouble shooting, ok so I got about 300ah battery (4x3 x 100ah 12v Lipo4) they charge fine. thats all the unit is doing so far because I read the manual and it really does not highlight how to turn it "on" when it is on. ok so I have to press a button for 2 sec. to turn it on. So what is Error F01 ? Bus voltage over, Power Company line in 124v/124v spit phase US Florida, solar cloudy day/rain 350v 12 panels 230w. Output reads 124v l1 / 124v l2.... works without power company (breaker off) for hours testing in shed with lights ~ 300w....
on futher reading under fault error F02, which THIS error is not, but educational, says bus voltage under , PV or battery disconnected suddenly.
so F01 would only be PV or battery???? too high?
with these batteries, I have charged them using PowMr 60A and they do spike in voltage as they fill up I assume, 17 volts on a 12v battery? happen to anyone?
The unit would never really use the battery, only pv, so acting like a Uninterrupted power supply.
well the pv input died 350v 8amp panel feed. I did not have any problems until I grounded the frames of my solar panels. Question
Could AC voltage get on the PV through the grounding???
Looking for information about the inverter I commented on your YouTube video. I guess I found you here also. I know you're still trying to get it to work.
I have been going through the documentation - Did you change the operating mode to Off-Grid?
