Been running my 4 x 200ah Lifepo4 batteries and 6 200w panels with no problems until today the E09 error code suddenly appeared.
Any ideas how to fix without sending unit for expensive repairs ( and postage!)?
From the manual, Error E09 is "Bus soft start failed" - not sure what that would mean exactly - as 12volt installs asked, did you try a complete shut down and restart of the unit to see if this resent something and cleared the error?
If you need some insight to the inner components of the MPP 6048 - here is the service manual attached. - note they call up the 5048 and 6048 in the same manual.
MPP 6048 Service Manual LV5048_6048 disassembly guide 201903A (1).pdf
