12v.What is the voltage of your batteries? Assuming they are 12V or 24V and not 48V. Something like 2 x Victron 100/30 charge controllers would be a good choice.
Victron for sure.Trying to pick the right MPPT(s) for my boat, leaving off the grid
2x 400W solar panels Voc 49.1V Isc 10,41
I’d like one MPPT per panel, for reduduncy
so what do you suggest? (and thx for the input)
sounds good. I don't mind a little extra $ when justified.Victron for sure.
MPPT 75/15 is the cheapest and can be enough for your needs.
If you have more $$, MPPT 100/30 is more powerful than the panel, so perfect for you.
If he only needs to top it off, sure. But if he needs to fully recharge, then 150A would fill an 800Ah battery in 5.3 hours. Versus 53 hours at 15A.Yes, it's why I edit my post.
''Can'' be enough because 400W panel will really give 200-320W depending of many parameter.
So obtain a real 15A at 13.2V (around 200W to battery) can be enough depending of the consumption.
WOW!!!!! Thx so much.Apologies, your OP did say 12V. There was another post today asking a similar question, got confused. Here is a general description of the process.
1) Most charge controllers are of an MPPT BUCK converter type meaning the PV input voltage must be at least 2-5V higher than the batt charging voltage.
2) Voc of the PV panels can never exceed the max input voltage of the charge controller.
3) The charge controller can be over-paneled with regard to Imp because any extra Amps available will be ignored and the system will perform better on poor solar days. Over paneling is usually limited to 20-25%.
4) The Victron 100/30 charge controller is rated up to 440W for charging a 12V battery so is a good match up with the 400W panel.
With 4 panels that means you will have 8 wires to your SCCs. And then 8 wires to your battery. I suspect once you start wiring this up, you will see the downside of this.
I recommend having 2 panels per SCC. For 2x 2P you could use 2x 100/30. For 2x 2S you would need a higher voltage SCC like an 150/30.
So, if you don't mind, buy more solar panelssounds good. I don't mind a little extra $ when justified.
Doh, i really got that wrong. I'm out. Carry on.He said he has 2x400W panels and 2x400Ah 12v batteries.
