Hello everyone,
I am getting ready to start this new build my own LiFePO4 battery, and last night I had a thought on charging the batteries for testing.
I will be getting a Amazon 30V/10A CV/CC charger. I want to run some capacity tests before installing in my RV. Draining is no problem... For Charging I figured I would just use the CV/CC charger, then I got thinking...
Could I attach the CV/CC charger to my MPPT solar controller and use the MPPT to charge the battery???
The charger at 30volts & 10Amps will produce 300 watts that will go through the MPPT and get converted to about 20 Amps.
Whereas just connecting the charger @ 14.5V it will charge at 10 Amps,
Will this work - my thought process says yes the MPPT will not care if the power coming in come the sunlight or from the charger.
Thanks
Thanks
