First - raise the absorption to 14.4 per battery 28.8 on the mppt. That will help get more power into the batteries.
Here are several important tests
1. Battery to mppt voltage: about noon when good sun and your system is in bulk.
Find the digital voltage of the batteries. Say 26.98v
Then find the voltage at the mppt’s terminals. My guess is it will be much higher than the batteries. (If not this isn’t your problem - but it needs checked).
If this is a issue - your batteries are not getting fully charged - even though the mppt thinks they are.
A couple of solutions:
Figure out how much difference and raise your absorption voltage that much.
Second (an expensive option) replace the shunt with a Victron Smartshunt or BMV712. Then setup the VE.Network- the shunt will send voltage, current and temperature(if you buy the optional temperature sensor) to the mppt via Bluetooth. This will correct the differences and the mppt will be using the battery voltage to make the decisions of when to go into absorbing and float.
2. Batteries at different voltages. When charging in absorption (or late bulk), read the voltage of each of your four batteries. Are they all the same? They should be very close. Do this test several times, late absorption would be ideal. Also, first thing in the morning before any solar - if there are significant differences you need to re-balance the batteries.
Good luck with your system.
