Hi everyone, I'm new here, been browsing around and came up on this site and decided to register as I'm a bit confused on my recent home setup, I had been using 2 hybrid inverters(powmr) and have changed to schnieder xw pro, inverter runs everything, what I'm puzzled about is the panel array, I have 22 panels, each 575watts, 11 in series for 1 string, 1 is 49v open circuit voltage 46v closed, so 11 is 506v @12amps, what I have noticed is that after adding both strings together in parallel and connect it to the schnieder 100 600 charge controller, when I log in to the insight facility I'm getting a max of 5.6kw in to the charge, I have 12.6watts of panel, I know it wouldn't be 100% match but I. Thinking there should be more especially in full sun when the panels have direct sunlight, is it a case where I need another charge controller? Could someone share some insight, thanks
