Hi,
I am rebuilding my packs with the new JK-BMS 150A 2A balancer.
There are 2 screws an each side but I want to use only one bigger cable, should I use only one screw on each side or should I link the 2 screws with a busbar first?
and with size that busbar should be then?
Thank you
Thank you all for the great ideas! I live in France and here it is prohibited to put 2 cables into one lug, not sure why but it its not compliant with the regulations so I'll try to avoid it just in case I have a problem and need the insurance...
The square piece of copper 740GLE suggested is maybe the safest option
So.....?In the United States, a DIY battery would be against code PERIOD.
With that idea I have ordered a busbar that I will bend straight from the negative of the last cell to the B- of the bms. Thanks againI stole the idea from the wago guy
Show me your JK BMS mounting solutions
I have a 16 qty bank of CALB 180 cells arranged in a 2p8s configuration and want to add the JK b2a8s20p BMS. JK BMS is aluminum skinned and came with short 7ga silicone insulated wires for connections, 2 in parallel for in and out. I can’t rest the BMS on top of the cells else short stuff out...diysolarforum.com
