I’m getting closer to installing my LiFePO batteries. I just read something I hadn’t thought of before. Actually, in a way the subject did come up. Previously, the issue arose that lithium house batteries may not be very useful to help the chassis batteries if they are too low to start the engine.
Now an added issue. I only recently found out my generator uses the house batteries to start. It was pointed out in an article I read that lithium batteries don’t have the current capacity needed to start a diesel generator. I do know that I usually have to crank the generator starter for some time when it is cold. Is this going to be a problem?
Question two. I was planning to add a DCDC charger to effectively use the engine alternator to charge the lithium house batteries. Now I learn about a product called a battery combiner that will need to be upgraded. I have no idea what one of those is. I read the description but remain confused. Is it the same as my Trombetta relay? Does it replace it? I know the two voltages of the different battery banks are compared to tell the system when to charge the house batteries when the alternator is charging? Can someone educate me on this?
Ed
’05 HR Ambassador Diesel motorhome
From amsolar.com:
2. Alternator Charging: When upgrading to lithium batteries you will need to upgrade your battery combiner for alternator charging. Without this modification, the higher resting voltage of a lithium battery will trick the existing battery combiner relay into thinking the alternator is running and the lithium battery bank will be paralleled to the starter battery, even when the ignition is turned off. The result is lithium batteries draining into the starter battery until they crash to a dangerously low voltage or the lithium batteries’ internal BMS engages, preventing further discharge.
If you have a lithium battery system that can handle a charging current of 150A or more (three or more Battle Born lithium batteries), and you do not have a smart alternator (here’s the Smart Alternator Test) you use the Victron Cyrix-Li-Ct battery combiner, variant “Lithium / 230A”.
The Victron Cyrix-Li-Ct can quickly charge a lithium battery up to about 80% state of charge.
If you have a smaller battery bank (one or two Battle Born batteries) and/or a smart alternator, you will need to use the Sterling Battery to Battery Charger. The Sterling is programmable for any battery chemistry and can bring a battery up to 100% state of charge.
Neither device is needed if you plan on using AGM batteries.
Estimated Installation Labor
High Current Alternator Charging
3 hours / $435
Victron Cyrix Battery Combiner
from 40.00
Victron Cyrix battery combiners connect your house battery bank to your starter battery and alternator to allow alternator charging. Additionally, when a charge is applied to a house battery bank the Cyrix will close and allow current to flow to the starter battery. Select an appropriate Cyrix based on your house battery type and alternator current rating.
Alternator 160A or less - 120A Cyrix
Alternator more than 160A - 230A Cyrix
Battery Type / Rating:
Select Battery Type / Rating AGM / 120AAGM / 230ALithium / 120ALithium / 230A
Quantity:
ADD TO CART
Sterling Battery to Battery Charger 12V/60A
425.00
This device is ideal for lithium alternator charger system upgrades in motorhomes where a smart alternator is used, or when the lithium battery bank cannot handle high current.
Ed
From amsolar.com:
3 hours / $435
from 40.00
Quantity:
ADD TO CART
425.00
