meetyg
- Jun 4, 2021
- 1,140
I found a nice explanation of common AIO charge/load priority setting (as in MPP/MUST/Voltronic):
At first glance, SOL and SBU look the same, but there is subtle difference:
*Please note there is a subtle difference between SOL and SBU – SOL will switch over to utility when solar is unavailable,
even if the battery is full. SBU will continue using the battery until its low voltage point.
Just thought I'd share this info, as I'm planning for my AIO installation and this subject has been recently discussed alot on the forum.
Optimising Your Solar Solution to Meet Your Home’s Requirements
Congratulations! You have taken the jump and bought an off-grid solar system with a Lithium ion battery to protect against load shedding and reduce your bill. However, you’re not entirely sure if you are receiving the maximum benefit from your new purchase. This is part 1 in a series on how to...
newfield.co.za
