windtrader
Just wading into the Victron family of products and looking for opinions on select products to do the job. There are many paths that Victron has provied for system integrators over the years and to a newcomer it can be overwhelming to determine what configuration offers the optimal solution today.
My goal is to integrate solar panels via a Victron solar charge controller, the smartsolar 150/35 to manage a small string of panels. Connect that to the battery bank (no BMS) and to a Cerbo GX to report state of charge and charge/discharge info. A Multiplus 24/3000 is connected to the Cerbo GX.
I've used a MK3-USB to update firmware using VEConnect. Where this goes is hopefully to use the Cerbo GX as the primary interface to the other Victron devices, meaning monitoring, configuring, reporting, data collection and updating firmware.
Is it reasonable to direct all interaction to the Victron products via the Cerbo and plan on all the collected data is made available through the Cerbo for later reporting and also for all configurations? If that is the case, is there any need for the MK3-USB device to connect directly to the components?
