justinm001
- Dec 18, 2022
- 1,620
Currently I have a 24v 70a alternator set at 27v then have a 24v 270a alternator set at about 28v. The big alternator is oil cooled, industrial and weighs like 100 lbs. Well the field wire came loose on the big one so I'm replacing it and now wondering if there's a better setup.
Currently have 24v chassis batteries and loads connected to small alternator the 4/0 from small to large alt then 2/0 40ft from the mfg to the front where the DC converters are swapping it to my 12 and 48v lfp systems.
I figured if the 270a has a higher voltage the 70a one won't really be doing anything and just sorta backup. Is this correct?
Any other options that'll be optimal? 270a alt alone pumps out like 6500w but since 2/0 I can only use like 145a or 195a which is 3500w or 4600w. I've always been confused on how much power I can safely pull from a cable.
I've also rewired my coach so all my normal loads go through the 12v 5kw inverter the the 48v feeds into this. The 48v feeds 4 of the 6 ACs and other high loads. I'm hoping Victron releases an Orion XS 48/12 and I'll go DC DC smart over DC to AC to DC. I figured if I'm on power reserve I can kill the 48v dual inverters and save 80w draw.
