wattmatters
Solar Wizard
If only you had kept on reading...I know you all think I am crazy
Bypass Diodes | PVEducation
www.pveducation.org
The article is talking about the theory of having a bypass diode for every individual cell. This setup does not exist.If only you had kept on reading...
www.pveducation.org
It describes the use of bypass diodes in panels to protect cells when there is shading. There are also half cut cells which help add another layer of protection in combination with bypass diodes.The article is talking about the theory of having a bypass diode for every individual cell. This setup does not exist.
Some do, some don't. REC, Trina, SunPower for instance do not explicitly say their warranty is voided due to shade. Others are more vague on the topic.There is a reason why solar panel manufactures will void warranty for shading.
Well....if the arrays power doesn't pass through every cell, where does it pass through?your original claim suggesting the whole power of a PV array passes through a single cell is nonsense.
Assuming you are referring to a string. Do you have a long flashlight with stacked batteries? The current stays the same, the voltage (pressure) goes up. The current is what makes it hot, that should be ~constant at whatever the worst panel can push. Most panels have multiple "sections" , if a section can't keep up current wise it will get dropped out of the string by the diodes, dropping the overall output voltage. They also prevent backflow in a parallel scenario. They've been building this stuff for quite a while, most of the safety stuff is pretty solid.Well....if the arrays power doesn't pass through every cell, where does it pass through?
Did you see the video I posted above? Clearly shows a damaged cell from heat.Assuming you are referring to a string. Do you have a long flashlight with stacked batteries? The current stays the same, the voltage (pressure) goes up. The current is what makes it hot, that should be ~constant at whatever the worst panel can push. Most panels have multiple "sections" , if a section can't keep up current wise it will get dropped out of the string by the diodes, dropping the overall output voltage. They also prevent backflow in a parallel scenario. They've been building this stuff for quite a while, most of the safety stuff is pretty solid.
This guy has a good example of a cell getting "COOKED" by the array. I time stamped it but earlier in the video he shows some glass cracked from heat vs impact. He describes how an impact will have the impact mark or circle and heat cracking does not have those crack patterns or circles.
In solar farm training, they utilize tracking meters to evaluate production losses from lower edge buildup, or animals blocking portions of panels, and schedule service.Did you see the video I posted above? Clearly shows a damaged cell from heat.
That solar panel shipped after being tested. Was it defective or a miss matched cell? There is not so much difference since all cells technically have defects. Most panels will have one or two cells that are the weaklings. Go out with an IR imager on a full production day and look at your panels. You will see some cells that are much hotter then the others. Usually just one or two. By the way, a tiny bit of shade is the same affect as a miss match as far as hot spotting goes.The hot cell is a defective cell. It's not the result of shading. This video is a compilation of damaged and defective PV modules - not the consequences of shading.
There are thousands upon thousands of used panels with heat damaged cells for sale used from solar farms. I have some.In solar farm training, they utilize tracking meters to evaluate production losses from lower edge buildup, or animals blocking portions of panels, and schedule service.
They aren’t worried about panel failure, they are maximizing production.
Do you seriously think a poop spot on a cell would damage a panel in a string of 1000 to 1500 V sets of panels?
So… all the degraded or old panels that are replaced with larger panels, and sold used… are they trash because of dust on lower edge cells?
The used panels I’ve gotten have not shown any damage like this… and I have used shattered panels for years…
a bit of a mess which generally gets washed off with rain. If it never rains, then a quick wipe is all that's needed.Bird poo creates
Just sharing facts. Take from it what you want. Some people have had issues, glad you haven't yet.Why are you rabbiting on about a non-issue? It's such a confected concern.
I completely agree. I won't buy any off brand panels anymore. I have some cheap panels with substantial hot spots, they are new and in full sun. Likely they will not make the full life cycle.Don't buy junk panels, don't mistreat them, don't do a poor installation and keep an eye on things in case something needs attention. It ain't rocket surgery. Fortunately the good manufacturers have done that for us.
Just sharing facts.
I don't have 5,000 watts of silicone roasting on my roof so I sleep good. Some people might not like what I'm saying for this reason. The mind has a hard time with new concepts that are a risk.
Yes of course, lol.....I don't think anyone is worried about bird dropping like that. Just trying to explain how partial shading can damage cells.1 in 3 homes in Australia has a rooftop PV system. The average installation size for new systems is now close to 10 kW. Yet amazingly there have been zero fires caused by bird shit.
China are approaching a production capacity of 1TW/year of solar PV panels. The paradigm on performance and quality has changed.To much energy concentration going through to much Chinese components
The vast majority of DC strings are typically well under 1500 V.I'm retired now but I use to work around very high voltage
