Texas-Mark
- Aug 4, 2021
- 1,409
So I have some Renolgy 100W panels that I have had in service for about 10 years. They are on the roof of my shed. These are set up as two panels in parallel (joined at the panels with Y connectors) in multiple "banks." The two lines from each bank come into the shed to a combiner, then to my charge controller. Everything was working fine for years. Then a few years ago we had a hail storm and bank #2 started acting up. I would have no current flow from that bank (measured directly across the positive and negative lines coming into the shed). Then suddenly they would start working again for a few days or even a few weeks. In other words they are very intermittent. I checked the Y connectors (no easy feat) and they seemed fine. Note: Even when I measure no current, I will still read 18V across the lines (while disconnected from the combiner).
So here is my question. Since I have two panels in parallel, other than the Y connectors, is there any individual panel malfunction that would cause this behavior? I had assumed one or both panels had suffered a hail strike that was making one of the internal panel connections intermittent. But I am not sure how one panel would affect the other in this way (no current at all). My next step I guess will be to separate the panels at the Y, and run them individually into the shed to see if it is just one panel acting up, or both. This will be a PITA to do.
