shadowmaker
Is it possible to somehow backfeed via critical load connection? It seems that my Deyes (2x Deye 12K, 3-phase operating parallel, but not in master/slave configuration) can charge my batteries more than PV+AC coupling enables. While the other is charging with extra 3,2kW, the other is feeding critical loads (=UPS-load in the picture) by about the same amount (well, not exactly the same amount as Deye app refresh time is different for each unit). Funny thing here is that my critical loads aren't connected to any load as that line is supposed to feed my main panel via automatic transfer switch only when utility is down. When utility is connected ATS is cutting this line. Still both Deyes are connected to it (thus to each other) via their critical load port all the time.
This one is charging with 9,6kW while PV+AC coupling is only ~6,4kW.
The other one has full battery already and is feeding critical loads with 2,1kW while there shouldn't be any critical loads to feed.
Any thoughts?
Any thoughts?
