Parallel of Serie
Peteronline
Geniet van de Zon
Ik heb momenteel 4 panelen van elk 100 Watt dus samen 400 Watt in Parallel aangesloten.
2 Batterijen van 12 Volt 100 Amp dus samen 200 Amp ook Parallel aangesloten
Mijn controller is een Epever Tracer 4210 AN van 40 Amp
Nu is mijn vraag of ik het best de Panelen in Parallel laat of in serie of deels serie deels parallel ?
Via Google Translate:
I currently have 4 panels of 100 Watt each, so 400 Watt connected in Parallel. 2 12 Volt 100 Amp batteries, so 200 Amp together, also connected in parallel My controller is a 40 Amp Epever Tracer 4210 AN Now my question is whether it is best to have the Panels in Parallel or in series or partly series partly parallel?
This might help: Figuring out how many panels in series and parallel based on your MPPT
Dear members I'm not that technical with all those calculations, that's why I place the data just to know if I can go for partly in Series, partly Parallel? with my panels and my batteries up to 12 volts?
I would like to connect them like the print screen below
The detail of my Batterys
2 x 12 Volt Acid Sealed 100 Amp together 200 Amp in Parallel
The detail of my Controller :
Epever Tracer 4210 AN 40 Amp
The details of my 4 panels are as follows:
Solar Panel Specification
Maximum power(Pmax) 100W
Maximum system voltage 700V DC
Open circuit voltage(Voc) 19.2V
Short circuit current(Isc) 6.87A
Maximum power voltage(Vmp) 16V
Maximum power current(Imp) 6.25A
Cell efficiency 19.5%
Operating temperature(NOCT) 45±2℃
Temperature range -20℃~+80℃
Number of cells 32pcs
Weight 2KG
Size 1050*540*3 mm
Standard Test Conditions : lrradiance 1000w/m2,Temperature 25℃,AM=1.5
