timselectric
- Feb 5, 2022
- 19,434
What are the red and black wires on the left connected to?
The thin ones? Those are PV wires to my solar array. Issue described happens with or without PV connected.What are the red and black wires on the left connected to?
Just grounding to that terminal won't do much good. Don't need that ground just using an extension cord. But neutral to ground at the generator chassis needs bonded.Predator 4375. I’m now looking at it and the front has a ground terminal. Now what do I do with it?
I’ve run chop saws. Skill saws, and my whole camper off the generator all of once no issues. Including the AC unit insideCan you run a simple double insulated low wattage appliance direct from the gfci plug?
If yes, can you run a 3 prong low wattage appliance direct from the gfci plug, preferably wearing appropriate PPE?
So using that plug will fix my issue? I don’t understand why. I’ve used generators to charge through inverters in the past with different setups over the years.I use a plug like this:
With the generator off check for continuity between neutral and ground.I’ve run chop saws. Skill saws, and my whole camper off the generator all of once no issues. Including the AC unit inside
On the generator or the inverter?With the generator off check for continuity between neutral and ground.
Your batteries have the alarm light lit. You need to get that figured out.Connected in Parallel. Then one positive and one negative to the main DC input on the inverter. System has been fully functional it outputs 120v AC. It accepts PV power from panels…. Just won’t take 120v AC input.
Is there’s a DC Ground fault could it be happening inside the Unit, manufacturing error?
DoubtfulSo using that plug will fix my issue?
Generator without the inverter connected.On the generator or the inverter?
I believe That is because of the low state of charge and why I am trying to charge them.Your batteries have the alarm light lit. You need to get that figured out.
I can't say for sure it will fix what you have going on. But it has fixed many RV inverter or EMS issues where those devices seek a NG bond with an external generator.So using that plug will fix my issue? I don’t understand why. I’ve used generators to charge through inverters in the past with different setups over the years.
No.Have you tried it with only one battery?
