Hello,
I have one of these solar panels, I would not mind to add more in the future, I have room for 4 panels.
Could you recommend me please parts for a DIY rig, with battery (starting with 1 solar panel) and I also would like to be able to connect a 120V / 25A 3000 AC WATTS generator.
In winter time the main purpose is to use it as an emergency power supply to my gas boiler, which provides heating and hot water. The boiler has a low power consumption, max 120 W, for a small pump and electronics. I also would like to use the solar system to provide backup or maybe even main power for a desktop and a laptop computer.
In the summer time I would like to add max 3 more panels (4 in total), and beside powering the computers, I would like to power a 240V variable speed pool pump, which can run as low, as 5-600 Watts.
Thank you very much!
480W | Black Solar Panel | QCELL - Q.PEAK DUO XL-G10
Deailed specs:Could you recommend me please parts for a DIY rig, with battery (starting with 1 solar panel) and I also would like to be able to connect a 120V / 25A 3000 AC WATTS generator.
