So, I’m thinking of setting up a system to supply power to a window A/C Unit (500-700 watts) from 3-8pm during the summer months here in Phoenix. Since most of that time there will be sunlight and solar panels are cheaper than batteries, I’m thinking of getting enough solar panels so I can run the AC just on them (even when it’s cloudy), except for maybe the last couple of hours. I plan to have a battery where 1200-2400 watts hrs. will be available to use. The question I have, is that on a bright day, and the A/C not running, the panels could be producing 1800+ watts of power which presumably the solar controller will direct that to the discharged battery. I don’t want that much power going into my empty battery as it would be excessive and either reduce it’s life and/or trip the BMS (if it’s a lithium 12v 100ah battery). I believe, in general, lead acid batteries maximum C rate is even lower then lithium and is .3 (AGM) or less. So, can I regulate the controller so it will provide enough power to run/not run the A/C Unit and charge the battery at a safe C rate. Or am I making something out of nothing. Hope this make sense.
