Will the PD4060 safely charge two Weize 100 ah Lithium Batteries in a Lance Model 1985 trailer which has a 190 watt solar panel and 1500 watt inverter? It’s a 60 amp converter with a switch for lead acid or lithium batteries located at the back of the trailer 20 feet from the two battery boxes. Am I correct in assuming each battery will be charged at 30 amps or a bit less on shore power? I watched a YouTube video by Will Prowse who indicated he would recommend it. I want to make sure the converter won’t damage the batteries. If so, would you recommend another 100 ah Lithium such as a SOK, Battle Born, etc? Regards…..
