For lead acid, deep cycle batteries are rated based on time (20hr is a common period) and amps delivered over that time scale. So if you wish to test a LA capacity you would takes its AH rating and divide by time to get amps and run your test to see if it can deliver that with not reaching low voltage shutdown. I see several methods that people are using to test LiFePO4 that makes me wonder if there is any universally agreed method for coming up with a capacity.
High amp draw tests to get the testing done quick would create the voltage slump situation under load leading to early shutoff.
Low amp tests are based on what current amount? Should it be constant current, constant load or and what is considered cutoff voltage?
When I have run the few tests that I have done I chose constant load since that seemed to me to be a good way to see if the battery would perform in a real world type setting.
