Purchase Lifepo4 battery
chayden
Hi,
I inadvertently purchased a 15s battery(let's call it battery 2, which is 48V 200 ah) to add to my existing 16s(let's call it battery 1, which is 51.2V 100 ah) battery system. The mixture of 15s with 16s I am now aware is not possible/strongly not advised due to voltage differences. Is it possible to add another battery in series with the 15s battery? Below is the specification I have for the 15s battery. If yes, can someone send me the link to a website to find what I need? The battery would of course have it's own BMS.
Nominal voltage(V)48
Nominal capacity (AH)200
Working voltage range42-56.25
Recommend charging volt(V)52
Standard charging current(A)50
Max. Constant charging current(A)100
Standard discharging current(A)50
Max. Discharging current(A)100
The right bms should let you do whatever you want to as long as you add a cell that is the same or reasonably close in specs, right? So I’d do that.
