All valid points and the Selterm ones are probably fine.I just like the fact that the Fusion ones are a lot thicker and these 2 connections are all about electrical conductivity ,not mechanical strength.I am an old plumber and I trust my soldering ability, so there's that. I have made quite a few battery cable sets for vehicles and it's not hard at all.
Other than this post and a couple more ,I am not seeing probably the most important component that’s required to soldiering of any kind . Experience ……..
I have soldered and created thousands of gold ,silver and platinum rings ,bracelets and jewelry items ..also worked copper plumbing pipes , …I owned a jewelry store/ repair shop and did all my own work for 2 decades…
There are so many mistakes that one can make in a solider joint and never Know it , it’s scary…
Cold Soilder joints , not fluxing properly , using the wrong flux, using weak or incorrect soider, not properly heating surfaces , not allowing the solder to chase the heat exactly where it needs to go. Over heating- underheating, damaging the insulation , not prepping the surfaces or properly cleaning all the surface , creating hard spots that can fatigue , stress crack and fail…
and much more…
I trained under some extremely seasoned jewelers and “metal working people”..
in most cases you will never know if you did it right , wrong , great or half -assed Untill it fails .
That only comes with experience …
NOTE….I am not a welder…that is a totally different skill .
all I’m saying is that a very good crimper tool and properly prepped / cleaned wires and lugs is a much safer bet for a person using larger wire who is not VERY good at soldering…it is not as easy as it appears..if your good ,then go for it ..if you are not, leave it be.
im sure better people than me electrically can speak upon the extra resistance a poor solider joint creates to mess with your system once finished.
J.
