So I have two years of great metering data that shows me that the right size inverter is a 6.8kW unit with 10-12kW surge capacity, running in parallel to my existing 7kW enphase system. Then the in-laws came during Christmas time... and we managed to have a grid outage at the same time (along with near-zero solar). Our daily consumption went up from 36kWh to 66kWh, along with seeing 10kW sustained for over an hour with 15kW surge for 10 minutes.
I have four big loads-- EV charger, dryer, hot water heater, and oven. Everything else is under 3-4kW in normal operation. Normally, hot water is more than adequately provided by a solar hot water system-- we used 8kWh of electricity for water heating in 2019. With the 6.8kW inverter I could manage the dryer and EV charger easily enough. It is a lot harder to manage with the oven and water heater added into the mix though.
So, the questions: 1) what do you size the inverter for? Simplicity-- let it handle the worst-case scenario at the cost of efficiency, expense, and space, and 2) If I do need a 1-minute surge of 15-18kW, what would you recommend for an inverter?
Part of me thinks I should stick with my plan for a 6.8kW inverter (XW-Pro), and parallel a second grid-tied inverter for when solar is down, but the practical logistics of doing that are a little beyond me right now.
