WarmachineX0
I've been trying to set up an off grid system for my house. I'm currently on a generator and would really like to get this working but I keep blowing up inverters.
I've got two of the of the BluePower SP6584 (pretty much the same as the MPP Solar 6584). Every time I turn them on, one blows. Not immediately, but shortly after.
The system consists of 10 (currently 9, 1 isn't working) SOK Batteries from Current Connected. 48v 100Ah Lithium Iron Phosphate (LiFePO4) battery. Two SP6548 with a Lynx Distributor between the two.
I'm pretty much identical to this,
With three exceptions. I've got more batteries. I didn't do the ground neutral bond in the box. And I have a Lynx Distributor instead of bars.
When I turned them on this last time, they seemed to come on fine, then I turn them off after a loud beep because I noticed the communication cables weren't attached. I turned them back on in plans to program them. After the loud beep one made a loud pop and the system turned off.
I did precharge them using the light bulb method. I pre-charged the previous time through the battery’s system. I did not turn the batteries off when I turned the inverters off so charging them again wouldn't be needed.
Any help would be greatly appreciated. I did try support but they couldn't figure out what the issue is. I'm now sending off for a replacement again. I'm not sure if I should just give up and do something simpler.
