Dinobot248
I am looking to replace my one EG4 6500 with a Victron kit. Never used Victron before. Tired of mediocrity and want something that just works well. I am open to suggestions / critiques.
Location: Northeast Ohio. PV array is oversized to compensate for shade / trees.
Current system -------
Single EG4 6500EX (another 6500 not used since house load is small enough)
30kwh Lifepower4 battery bank
10kw worth PV
Future system --------
Victron kit composed of two 48v Multiplus II 5kva running 120v parallel (don't need/use 240v), cerbo, distributor, shunt, etc. Link below
10kw worth PV
Planning to add a DIY 15kwh battery (16 x 305ah grade B cells)
Some questions
What are disadvantages to using two EG4 6500 as solar charge controllers such as can't see incoming PV, can only see battery charging via shunt. Trying not to spend the extra money on a Victron SCC.
I picked up two Victron MPPT 150/45 SCC during the recent price drop. How many Victron SCC can be connected? I want to use them if I can.
10kw worth PV
10kVA 120/240V Base MultiPlus-II Power System | Current Connected
Embrace independence with our modular 10kVA MultiPlus-II Power System. Unleash the freedom of off-grid living without sacrificing comfort.
www.currentconnected.com
10kw worth PV
Some questions
