Hi all, this is a kind request for a improved guide on building LifePo4 DIY battery packs.
Existing guide https://www.mobile-solarpower.com/design-your-own-12v-lifepo4-system.html does not mention details like below
- Compressing cells
- Direction to place cells
- Best cell arrangements (for 8s, 16s)
- Torque to be placed on Cell terminals
- Whether to keep a insulated material between cells
- Suitable enclosure type (Metal vs ABS material)
- Avoiding bus bars touching the battery case
- Avoiding battery casing touching the enclosure (if made from metal)
- Where to place the temperature sensors of BMS.
- What to do when the no of temperature sensors in BMS is less than cell count (which is usually the case)
- Ventilation requirements if any
- Placing more temperature sensors (in addition to ones from BMS)
- Compressing cells
