erik.calco
Solar Badger
I ruled out running wire underground with PVC due to insane effort, more bush and tree roots than I have pairs of socks, and challenging updating it down the road. Since PV and landscape wire is already weather proof, you really just need to protect it. How do you run it above ground aesthetically in a semi-wooded area? Through wood, of course.
Never did an angle cut with my circular saw, the most handy power tool that God created. So, I'm a little proud of my accomplishment today. I previously cut down a tree with one. lol
You can see from the photo I did two cuts. Below I show how I used a website calculator to find the entry distance of each cut, 45 degrees, 1.5" deep. Made sure I could pull through anything with 1" or less diameter (MC4 connector) with a little extra space for wires, though I'll always be able to unscrew the cover I'll put on it. This block will actually be facing down with wider boards covering it that will become the bottom. But, you can flip it over any time to open it.
Currently with fence pickets face up:
Triangle Calculator
This free triangle calculator computes the edges, angles, area, height, perimeter, median, as well as other values and a diagram of the resulting triangle.
www.calculator.net
