You need one good charging source to charge the batteries the way they want/need to be charged. - usually either a good solar array or a good lithium charger. In my MotorHome I put in a Victron Multiplus inverter/charger. That was it does both charging and gives me the inverter power I need.
If you always incompletely charge the lithium batteries the BMS never gets a chance to balance the cells. Then one cell will drift low and one cell drifts high. On charging the high cell will trigger the bms to cutoff because it gets too high, and the low cell will trigger low voltage disconnect when using because it is too low. Your battery will not have the capacity you paid for and I have read stories here where it got really bad and was hard to fix. Just make sure you have at least one source that charges it to full.
