John Frum
Tell me your problems
- Nov 30, 2019
- 15,233
Suggest you test it with the lead acid battery as a baseline.First of all—thank you!!! This was incredibly helpful for me ?
Did not know what a breakaway system was but I noticed a set of wires coming from the brake lines and wondered if there was some sort of similar mechanism! Clever… although it wasn’t hooked up ? I’ll change that in the future.
Yes.This makes sense now, so I’d be running a new set of wires from truck to trailer. Would there be a plug on each side, just like the 7-pin setup?
Something like this.
This can be done later but you need to have enough battery capacity to run your fridge and whatever else will be left on plus cover the breakaway system.I have a 1993 Ford F-250 diesel with 2 batteries. I’ll take a look out there later. Question though: is this something I could add in later? Or maybe plumb the wires only for now?
More testing than that will be required.I am a fan of simplicity and eliminating weight. Ok, so what would testing that look like? Could I just use a voltmeter to make sure it’s getting the proper load, or is that not sufficient?
I would not trust this until I functionally tested all modes.
Of the cuff I would say you should trigger the breakaway system and see how it operates with the lead acid battery.
Try dragging the trailer to get a sense of the resistance maybe.
Anybody else got a good idea for a functional test that doesn't involve detaching the trailer and seeing if it sails off a cliff?
