The Samlex 2224 Inverter Charger panel has Output Neutral, Output GND, and Output Line; I believe this is where I get AC from this huge inverter. I bought a range box (2G 34 CU adjustable), receptacles (15A grounding duplex outlet), and switch (15A Single Pole Toggle Switch) today at Home Depot. I did not buy wire because I didn't know if it was 15A, 25A, 50A; does anyone know?
Does this connection use Romex wire and if so which capacity? Also, does anyone know how to wire a receptacle and switch? I was thinking of having the switch turn off the receptacles. I would hire someone to do it but the only people working are extorting or cons.
