noy897
double posted sorry - close this thread
Permits are from the Municipality for safety purposes. Permission to Operate (PTO) is from the Utility to protect the grid. If you do not feedback the grid, then you don't need PTO. Almost anything of significance requires Permits.
You can build an off-grid system that does not require PTO, but will probably require a permit.
If you have decent net metering, you might want to go the PTO/Permit route and avoid having the cost of batteries.
Can you explain why would it not be enough? Im assuming it has 21kwh of capacity and with 6-10 hours of sunlight that should be sufficient amount of charge to give my tesla. What am I missing here?You don't need a Permit to purchase it. If you want to install it to power you house, you may need a Permit. If you just plug stuff into it, you don't need a Permit. I see it has 2kw of panels. Not enough for what you want to do.
When the sun is low in the sky you don't get full production. Output is more like a sine wave as the sun rises and sets.Can you explain why would it not be enough? Im assuming it has 21kwh of capacity and with 6-10 hours of sunlight that should be sufficient amount of charge to give my tesla. What am I missing here?
10 hours is excessively optimistic. 4-5 hours the rule of thumb people use for a lot of latitudes in the US. This will handwave away the fraction of full power at the beginning and end of the day. And that's average over the whole year.Can you explain why would it not be enough? Im assuming it has 21kwh of capacity and with 6-10 hours of sunlight that should be sufficient amount of charge to give my tesla. What am I missing here?
