42OhmsPA
What's in a title?
I'm ready to order the SGP inverter linked below, except for one holdup...
Hold do you interpret this wording from the manual?
"HOT1 load> HOT2 load, HOT1-N must be used preferentially for single load, The total load connected shall not be greater than the rated power of the inverter"
Screenshot to sellers response, which still has me confused, attached.
My plan is to rewire the main panel of my house using the inverter, solar and battery as the primary supply; having the grid as a backup.
If I can't use H2 to N for 120V loads the inverter won't work for me... H1 and H2 would feed the buss bars in the main panel...
Thanks to everyone who has made this forum what it is, there is a plethora of information and great discussion. It reminds me of my days on VWvortex. I wouldn't have anywhere close to the knowledge I do now if it weren't for everyone here.
8KW 48V Split Phase Solar Inverter
Highlight: ★ All in one unit: 8KW Pure Sine Wave Solar Inverter Combined with Max 200A battery charging, 2 MPPT Solar controller inbuilt, Max.Voltage of Open Circuit : 500VDC, Split phase (120V/240V) or Single phase (120v) output. Wifi module is included, which allows the user to view the...
sungoldpower.com
