Can you do this. Say I have 4 strings going into a combiner box and then run 3 larger cables (1+/ 1- /1G) to the inverter works fine but adding another inverter to a different load center and in no way connected to the first system, could I share the PV input lines? I see others sharing battery/power with inverters but how about the PV lines both inverters using at the same time? May be this is silly but would it work.
