Minimoose
My son is getting a shed delivered later this month and wanted to solar power it as it's far from the house. He's only planning right now to power a ceiling light,small fan, and a battery tender. He wants to hard wire an outlet or two and a switch for the light. He wants to run a ground rod for the inverter and outlets, but it will have an open ground anyways like an ecoflow. It's a reliable brand inverter and if I'm understanding they recommend not bonding. My question...... Is the grounding rod necessary and if so should the solar panels be grounded there too? The panels will be on a metal roof so can he just ground the whole roof?
The panels will be fused to the mppt. The mppt will be fused to the batteries. The batteries will be fused to the inverter. The inverter has overload and short circuit protection which I'm assuming is the internal fuses. I have the same inverter for backup, but I kept mine portable and don't plan on mounting it because I just use the built in outlets. His system is.....
Four 100 watt panels
mppt 40 amp
Three 100ah agm batteries in parallel
Reliable 3000 watt inverter (which will never see anywhere near 3000 watts) I had him oversize it just in case he wanted to run a power tool or shop vac.
Thanks for any insight.
mppt 40 amp
