myersfamilyhome
- Feb 9, 2021
- 140
So my 16 LifePO4 cells are stacked on there side in 2 vertical columns because of space requirements. My question is, since the coldest cell in my bank is closest to the floor, can I connect the victron SmartShunt Temp Sensor to the lowest positive cell terminal in the stack (cell 8 so that I get the coldest reading from the bank or do I need to connect it to the end of the series of cells? I can't tell via the data sheet what the voltage requirement is for temp/shunt operation off this lead is.
