SolarRat
I’ve got that same clamp meter. Good stuff. For measuring my AC lines I bought an AC line splitter. Make things so easy. ?
That's exactly what my cable does, same idea.
While this pi monitor is super neat, it's price makes no sense. Emporia VUE with 8 CT is $99.If you are looking for more of an energy monitoring system, check out Open Energy Monitor.
Home | OpenEnergyMonitor
openenergymonitor.org
I built something like this a few years ago for my well control system. My system used some of the basics from the OEMon project but it does a lot more than just energy monitoring. It provides overload and underload (dry well) protection for the pump and manages the pumping cycles to avoid excessive draw down.
Mars
I made my vary similar (with a wooden frame) the best part is that the kill-a-watt only supports more or less 1800w, with this meters there is almost no equipment you cant measure and if you use 2 meters and 2 outlets you could measure 240v equipment and 120v equipment, one coil measures two wires (one from the 120v outlet and one 1 from the 240v outlet) the other coil only one wire from the 240v outlet and with a selector switch would turn on one or both meters, that would be like selecting 120v or 240v, for the power input you would need a detachable wire so you would connect the right terminal for 120v or 240v, maybe with some anderson plugs, just an idea that cross my mindI was not keen on the reviews for the P3 "Kill-A-Watt" meter based on the Amazon reviews. So I bought these:
Put my Sherline milling machine & drill press to work & fabricated my version of the "Kill-A-Watt" meter.
- AC Digital Meter, DROK Current Voltage Amperage Power Energy Frequency Factor Multimeter
- Leviton 5361-I 20 Amp, 125 Volt, Industrial Heavy Duty Grade, Single Receptacle
- Ogrmar Plastic Dustproof IP65 Junction Box DIY Case Enclosure (6.9"x 4.9"x 3")
- [3PACK] 90 Degree USA Canada Male Plug Nema 5-15P 3 Pole Angle DIY Plug
- 4' of 12AWG industrial extension cord from the local Ace store.
- Bits & pieces from my ready spares/consumables supply.
Excellent! I assume it's ability to capture microsecond peak amps is better than the killowatt?
Microsecond? At 4 GS/s my setup can give nanosecond resolution; 8 meg memory depth that would be limited to 2 ms capture, 1/8 of a line cycle.
But not with the current transformer, and not the HV probe, due to their bandwidth. Only with suitable voltage probes.
Why? Because we can.
That's just my lower end home system.
Recent job, I was measuring 5 kV 100 ps pulses into 50 ohms.
All it takes is the right equipment (and deep enough pockets)
Keysight DSAZ634A 63ghz 160gs Scope Super Loaded Cal Plan to Nov 2024 for sale online | eBay
Find many great new & used options and get the best deals for Keysight DSAZ634A 63ghz 160gs Scope Super Loaded Cal Plan to Nov 2024 at the best online prices at eBay! Free shipping for many products!www.ebay.com
my boss noted that scopes run about $10k/GHz, which would make this one a bargain.
Check out https://www.themeterbox.comHey all, I'm sorry to jump an old thread but this might be close to what I and more than a few others are looking for. I have a large freeze dryer that has a Nema 5-20 plug and draws a peak of 16 amps on a 20 amp breaker.
Have exhaustively searched for a 20 amp rated kill-a-watt meter that measures current usage and elapsed usage (amps, volts, watts and most importantly, KWH).
Does this set up measure these both current and elapsed?
Could anyone help me with a build or instructions to build? I am probably not qualified to do this but my electrician might be able to.
Thanks for any help you can provide...there are a lot of us begging for a meter that will work ...
Thank you sir! This might work perfectly! Checking into it???Check out https://www.themeterbox.com
They do exactly what the OP made. It's original intent is to track power usage of Crypto miners, but they are just a glorified kill a watt with current/watt usage and elapsed usage.
