Hi All
Getting a bit dizzy looking at 12v LifeP04 charge settings for our RV.
My setup
2x190W GoPower Panels
2x100ah GoPower SunCycle Batteries
Victron MPPT 100/30
Progressive Dynamics PD9160ALV Lithium Converter
Victron Smartshunt 500a
Q1. The PD9160ALV charges at 14.6 and then floats at 13.6 , should the MPPT controller be set the same? Most of what I read here indicates the solar controller should be set to 14.4 and float ranges from 13.5 to 14.2.
Q2. The batteries have a BMS. Does the BMS take care of equalization or should that be set within the MPPT. If it happens with the BMS should the MPPT equalization be set low so as to be effectively disabled?
Q3. The MPPT needs a charged voltage set. Is that the same as the MPPT float setting?
Q4. When and how do I set the SOC on the Smartshunt?
Thanks in advance. Just looking for a set it and forget it configuration
Britt
My setup
Victron MPPT 100/30
Britt
