Dhalbmaier
I have a new (8) panel array on a pergola, Trina Vertex S 390 watt panels. I am controlling it with a Sol-Ark 5k inverter which I like the features on. Since I turned the system on in November I get lower power generation numbers on sunny days vs overcast days by a lot, like 70% less. I have been online with Sol-Ark and had them login to my system to check settings and they have no explanation. Checked each panel with volt and amp meter and they are all the same, not sure they are correct but are generating the same output. My array has some shading from tree branches now that sun is low in the sky, I'm in Minnesota. Could the contrast from sun to shaded areas on the panels on sunny days cause the inverter MPPT or the panels shade optimization features to shut down power generation. Somethings wrong and I need help figuring it out. Could not find anything useful on general internet search so I'm turning to the experts here. Thank you.
Power calculations based on Trina Vertex S 390 watt PV panel specifications
String voltage: 8 panels x 33.8 (Vpmax) = 270.4V
String wattage: 270.4 x 12.34 (Ipmax) = 3,337 watts (per string)
Maximum string voltage: 8 x 40.8 (Voc) x 1.25 = 408 Volts
Maximum Current: 13.08 (Ic) x 1.25 (Irradiance) x 1.25 (NEC) = 20.44 Amps
