scarpenter002
- Sep 22, 2019
- 5
I am in the process of designing an RV solar system, 400 - 800 watts of panels, connecting each pair in series, then grouped in parallel. Wire from the roof to the controller will be 8awg. My controller will be an EPEVER 80 amp MMPT w/ MT50 remote meter. Based on the configuration, I was calculating approximately 35 amps at 24 volts (800 watts of panels). Just wondering if there would be any issue installing a breaker between the controller and the panels, to allow for the ability to shut off current from the panels?
If yes, would a 40 amp breaker work? (I may start with only 400 watts, then add another 400 watts.)
My controller will be in my 5th wheel basement, where I will have easy access to the breaker.
Thanks for your input.
Scott
Scott
