Solis RHI-S6-EH1P-K-H-US HV Hybrid Inverter
Now if someone knows where to get HV batteries for $200 per KWH, I'm all ears. The availability of cost effective HV batteries would change the inverter marketplace.
The design parameters make it look like a version of the Growatt MIN11400TL-XH-US. Specs aren't the same exactly, but it is clear there is a connection.
Mike C.
Solis is the third largest solar inverter manufacture in the world, and the S6 it isn't a copy of anything. For systems below ~20kWh of storage, even with the higher cost per kw of storage, it is lower cost than eg418k or Sol-Ark 15K as right off the bat the inverter is 5K lower cost and then the balance of systems costs are lower as well..
If you don't require UL9540 listing, there is the Seplos Hiten which is similar in cost per kW to the 48V batteries. I have two on order and will post about my dual S6 system ( 23kw backup rated , 36kw surge ) when its all completed.
