Cooperman
S5-EH1P5K - 3 x Puredrive 2 5kw DC - 2 x Zappi
I am having issues with my system, it has always drained batteries into Zappi unless inverter is charging, so I have finally had a second zappi installed and the feed to both Zappis moved to their own external consumer unit from a Henley block. I thought moving the CT for the inverter to the feed to the house consumer unit would cure the problem as in theory the inverter would no longer see their draw. As soon as the Inverter CT clamp is moved to (position 2) after the after Henley block it either starts to charge the batteries or it turned around it discharges to grid. If it is in position 1 it functions correctly but sees the Zappis and throws the battery into the car. System has Eastron Meter
Inverter Settings
Meter type "Eastron 1ph Meter"
Install on "Grid"
Inverter Settings
Install on "Grid"
