Thank you.Yes, but not much. A 1/2 inch between them is more than enough.
Thank you.
My panels are 41 inches wide, is 1/2" still enough?
1/2 inch is plenty. I have both 60 cell and 72 cell panels and left 1.5 inches between the columns. After 5 years in Michigan with temps going from -30 to +96 degrees, I have never detected any shrinkage or expansion. I'm sure its there, but you'd need a caliper or micrometer to measure it.
The clamps I used provided about 1/2" between the panels and I've gone from temperatures in the 90's to low teens with no problems. I have big 72 cell panels and believe they're 41" wide.
-30 is not normal here. Zero is normal during the deep January freeze, even -10 is common. Extremes down to -15 might happen once a year if conditions are right but it's not every year. We hit -40 once about 6(?) years ago and my wife burned her lungs shoveling snow with me. I've been in it before and had a face mask on to temper the chill before it hit my lungs, but she didn't.I can't imagine -30 degrees. I grew up in Pittsburgh and remember complaining about temps in the teens some mornings going to wait for the school bus.
My stepmother grew up in Duluth and she used to say "kid, you don't know what colds is".
According to one of the manufacturers of rails system (prosolar) you can go up to 30 panels side by side before you would run into any kind of problem.I would argue that none is needed.
Based on what I see in your mount, there are solid spacers or clamps filling the gap between the frames. This does not allow for expansion.
They are solid T shaped aluminum clamps made for solar panels.
I never said they did. I don't think thermal expansion is an issue at all. I'm sure it's happening to some extent, but at such a small amount as to be irrelavent.which would not allow for expansion.
What?Across the stated temperature range a 41" wide panel would increase by just over 1/2 inch from low to high.
What?
That sure is a lot of thermal expansion.
I'd say the OP and everyone needs some room for thermal expansion, but not much.
By some random 30 second dig, 0.533mm would be a rough expansion number for the aluminum frame 41" wide. (Glass has lowe thermal expansion)
That would put the long dimension at roughly 1mm of expansion.
That is if my random Google and 30 seconds of math is correct. But I don't think we'd see 1/2" of thermal expansion in a panel.
Sure, panels expand with heat and shrink with cold, but so does what they're attached to. Aluminum panel frames attached to aluminum rails will see zero relative expansion. Aluminum to wood or steel will, but even when there is a difference, the materials give a little and never experience anything near their yield strength or UTS. I've seen commercial ground and roof mounts that allow for zero expansion.
Yes, if you mount solar panels with zero clearance between two immobile blocks of stone, you will likely regret your choice, but if your array has free ends like in any ground or roof mount installation, you're good.
Consider that panels themselves are made of dissimilar materials. Glass and Aluminum have markedly different CTE.
I’d appreciate seeing pics of your support structure from the other side.The clamps I used provided about 1/2" between the panels and I've gone from temperatures in the 90's to low teens with no problems. I have big 72 cell panels and believe they're 41" wide.
Why not? what are the implications?NOTE: Never attach Aluminium to PT Wood ! Isolate the aluminium and use Stainless Screws/Bolts to attach to PT Wood.
