This is my first Diy battery rack. Any advice on how to improve it or important things i may have missed?
Post up pics of the gutters above.
Interesting choice using network cable gutters.
Not sure that meets code.
Nice work! How much it cost you per kwh (just the material)?
Lets see.
48 cells went about 5.5k eur
3 jk bms around 300 eur
Dc breakers 240 eur
T fuses 180 eur
The 12 beefy springs costed me 100 bucks in total
Around 50 bucks of pla
And maybe 250 eur of other stuff (threaded rods, steel bars, screws, etc)
So in total about 6.6k, and for 48kwh that is 137.5 eur, lets call it 140 eur per kwh
I guess my only suggestion is cover it all so terminals aren't exposed but if thats located in a controlled access space then would be a shame to not be able to appreciate its beauty
I am thinking about making an enclosure for the whole thing. With transparent polycarbonate on the front of course :ROFLMAO:
I thought that a little margin wouldnt be important, i can not fit objects more than 200mm in my 3d printer. I hope that is not too bad
Factory specs are compression against entire face, but you could possibly add a taller shim (of steel that's sufficient to not deflect) in the ends to get there?
